Engine shuts off while driving?
DRCRANKNWRENCH
  • 3,380 POSTS
The first thing that I would look into is the Idle Air Control Valve, IACV, which is sometimes also referred to a the engine Load Sensor, ELS.
This is an electro-mechanical device which idles up the engine when loads such as; power steering, A/C and other accessories or situations call for it.
Electric items are tough as they fail intermitantly.
Other suspects are vacuum leaks and emissions items such as the Exhaust Gas Return Valve, EGR.
Listen for a vacuum leak while the motor is running under the hood. Also, Try running a can or 2 of BG44K. It will work wonders. Make sure to change the oil afterwards as it works so well, it makes the oil really dirty.
Pull the plugs and tell me what thney look like and listen for a vacuum leak and get back to me and we will go from there.
It can adversely affect the performance of the engine.
It is tough to diagnose problems such as these because electric/mechanical control modules feed from sensors all over the engine and accessories which makes it hard to tell if a sensor is bad, the control unit is bad, an IACV is a control unit that sometimes has integrated sensors, or if the is a problem with the Vehicle Main Computer.
Monday, September 21st, 2020 AT 11:55 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Is engine light on? On these newer vehicle just about everything will trigger the engine light. If it is on gettting codes read will assist in determining the cause of the problem.
Here are a couple other possibilities besides vacuum leaks.
TPS - Throttle Position Sensor
MAP - Manifold Absolute Pressure Sensor
LUVCAMPEN
  • 2001 DODGE CARAVAN
  • 6 CYL
  • 14,000 MILES
My van stalled on the way home the other day, it suddenly lost power and shutdown, I restarted it and had to flutter the gas pedal to somewhat keep it running but barily. Code #106 came up and we replaced the MAP sensor. Took it around the block 8 or 9 times was about to take it on the freeway and it stalled again. I decided to change both 02 sensors. Drove it aroun, took it on the freeway, ran fine (The day was cooler). Started it up the next day took it around the block got it up to temperature and it did it once again. I decided to change the fuel pump and fuel filter, took it around the block somemore and got it up to temperature, again it stalls. Codes 107 & 121 are now coming up and we changed the TPS sensor with no change. Does anyone have any suggestions on where to go from here?
LEGITIMATE007
  • 5,121 POSTS
At this point I would check the crank position sensor, these codes never come up, when bad. But it may be causing the other codes as these sensors work together.
BRIAN WHITE2
  • 3.3L
  • V6
  • FWD
  • 170,000 MILES
Well it starts, but when you start to take off it dies, and it will start and die again.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge auto parts rent it, sounds like a pump.
JSPIBY
  • 3.3L
  • V6
  • 170,000 MILES
Driving down the road approximately sixty five miles an hour, the engine shuts off. Could this be crankshaft position sensor?
HARRY P
  • 2,292 POSTS
It could be the CPS. In all honesty, there are a lot of things that it could be. Diagnosis is needed. Is the service engine/check engine light on? If so, get it scanned with an OBD2 scanner and get back on here with the code number(s).
If the service engine light is not on, then the issue most likely is not sensor related. I would suspect either a blown fuse or a bad fuel pump. Start with checking all of the fuses. Your owner's manual should give you fuse box locations as well as the layouts.
Start there and let us know what you find.
JSPIBY
I switched out some of the relevant relays, checked all of fuses and they were good. Engine light does come on with the code of P is in Paul 0601. When I turn on the ignition I can hear the fuel pump primed briefly.
Monday, September 21st, 2020 AT 11:56 AM (Merged)
HARRY P
  • 2,292 POSTS
I've seen the P0601 on Chryslers before. What it means is that the Powertrain Control Module (PCM - Main computer) can't correctly communicate. Additionally, since it can't communicate, it can't set other codes indicating other problems. The control module needs to be replaced. There are services on ebay that can fix the original computer, but I wouldn't suggest that unless there's no other option.
So you'll have to address that problem and then see if (1) it continues stalling and (2) what codes come up.
Let us know.
COOPER29
  • 155,000 MILES
I was driving and my air got really hot. Then the emergency brake light, battery, and abs light came on. The radio cut off and the windshield wipers with the fluid came on. Then the car wouldn't start back up. I just got a new alternator and starter. What could the problem be? I got my battery checked at advance auto and the y said it was good.
TY ANDERSON
  • 719 POSTS
Does the engine crank over and not start up? I've seen some of the wiring under the hood get melted and short circuit together an this causes a lot of random symptoms. Have the computer checked for any fault codes. Start here and get back to me. TY
DINOSORNA
  • 6 CYL
  • 135,000 MILES
I recently visited your site (and I love it) I found that my 2001 3.8 L Grand Caravan was going into Limp in mode occasionally since about Dec of last year I changed the transmission input sensor and this did not help. I also disconnected the battery for 24 hours and this didnt help so I replaced the crank shaft sensor and Bingo the check engine light went away and the tranny shifted great. Drove fine for a few days then died suddenly again. It always restarts but this last time it didnt start right away and I had to get a tow. It started fine the next day. When it died last time I turned the key and where you would normally see the digital mileage reading I saw the letters d.O.N.E No kidding! Any ideas? O2 Sensor maybe? Im running outta money and patience. Thanks!
Signed,
33 year old mom of 3
MERLIN2021
  • 17,250 POSTS
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear. Post all codes that appear.
MBIZALDI
  • 6 CYL
  • FWD
  • 166,546 MILES
WHEN I STOP AND PARK THE MINIVAN SHUTS OFF I START AGAIN AND THE ENGINE SHAKES AND IDLES BAD FOR ONE MINUTE THEN NORMAL AGAIN. THIS HAPPENS ONCE ADAY. CHANGE PLUGS, COIL, WIRES AND RAN GOOD FOR 1 MONTH.
CH112063
  • 1,320 POSTS
The way you describe this, a plug may be misfiring. If it's new, before starting, see if any or just one is oil or gas fouling from an injector or mechanical oil control problem. That plug or plugs will tell you which of the cylinders are acting up. OK
DHAMLETT
  • 6 CYL
  • 133,000 MILES
2001 caravan 3.3 v6. It is running rough and stalling however it is throwing no engine codes. It starts right up, most of the time. The engine revs fine with no load. Once a load is applied to the engine, it starts to run rough and may stall out.
(this is my sons vehicle at college). I went to his school and trailered it home and did the following; changed the fuel filter, plugs, and wires.
I took the van out for a test drive and it ran GREAT! I did some shopping around town, and stopped at many traffic lights, no problems.
My wife drove it to work the next day, and took the kids to soccer practice, no problems.
Day 3, my wife drove it to work and we had to have it towed home, still no engine codes.
I've been reading on this site and I've come up with the following possibilities; fuel pump, (O2, map, crank, cam) sensors. If I buy all of these, it will cost me about $500 and no guarantees.
Question: do you agree that it could be any one of theses things? Do you have other suggestions? In what order would you replace the items in my list.
I forgot to mention that I did test the fuel pressure and it was 60psi but I only ran the test for 30-45 seconds. I'll figure out a way to hook up the gauge and drive it around.
Thanks.
CH112063
  • 1,320 POSTS
You know, the way your describing the problem, replacing the fuel filter and the tune-up had it running fine for a few days, if it was my sons van I would drive it around with a fuel pressure guage on it but if you don't have one you must remember tha the van was made to last 70,000 or 7 years. If you have not ever put a fuel pump in it and you want to just make a guess, put a fuel pump, fuel filter, and make sure the fuel is not contaminated. There is a screen called a pick-up screen on the pump, replace that also. So if new pump, filter, and pickup screen, gas clean, then the only thing left is a fuel pressure regulator or maybe an injector. If it's not running now and no gas, fuel pump no good. Just be sure it is not a bad fuse but putting a fuel pump in the gas tank was a very common job and a 3.3L that has so many miles should have a new one anyway. Those sensors usually always throw a code. I would change the pump if I had to guess. Make sure about all those items with the pump. Filter, screen, fuel contamination. It should be done anyway. But if you are a professional, you must tell the cust. It is a guess. Better to use a guage.
