wife filled her van with gas + - 5 gallons and approx 30 min later started acting up, tried dry gas, injector cleaner added known good fuel, replaced fuel filter, (tested fuel pressure, turned key on 53-57psi , started engine and gauge went to 60 psi and bounced steady around 60psi,) engine starts pretty easy and runs for a minute or so then idle surges up and down in short consistant cycle then stalls, engine will run erratic if you hold @ high rpm and moveable with foot on gas and brake, seems like it is starving for fuel? i cannot locate fuel pressure regulator?
( don't know if this helps but this is flex fuel vehicle)
been tinkering with this for few days know and am getting exhausted , any help suggestions would be greatly appreciated
Jul 29, 2010 at 1:58 PM
