2004 Isuzu Rodeo Question starter/solenoid
2004 ISUZU RODEO
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOELSPEAR
how do I replace starter/solenoid
Sep 6, 2010 at 6:52 PM
  • 31,937 POSTS
With the starter removed from the car undo the main field wire (large wire going from solenoid to starter body, and undo the end screws on the solenoid, it should then lift free, not sure if you have to twist to unhook the bendix lever , but this should be quite evident when you get that far.
mark (mhpautos)
Sep 6, 2010 at 7:47 PM
