1992 Isuzu Rodeo Question who is responsible mechanic or me
1992 ISUZU RODEO
166,900 MILES • 6 CYL • 2WD • AUTOMATIC
FRSKYGIRL
I took my car engine rebuild they broke and lost pipe intake/to manifold he wants me to pay original agreement was 1150.00 + tax then 400.00 + then additional 520.00 my car broke down two days later oil leak, power stearing leak and radiator has oil in starter wire were loose nuts bolts were loose and im not sure if he did put the parts on my car he claims
rebult engine
water pump
hoses
clutch kit
fuel filter
injectors
spark plugs
I dont understand how when that kind of money is invvolved shouldent it run
Feb 3, 2010 at 11:38 PM
JJ78641
[quote:be57bc1a81="frskygirl"]Warranty problem
1992 Isuzu Rodeo Question 6 cyl Two Wheel Drive Automatic 166900 miles
rebult engine
water pump
hoses
clutch kit
fuel filter
injectors
spark plugs
I dont understand how when that kind of money is invvolved shouldent it run[/quote:be57bc1a81]
You need a new mechanic and did he warranty his work?
Jul 17, 2010 at 11:00 PM
BILLYMAC
  • 2,204 POSTS
Hi
Well unfortuneately most of the probs you have are all his fault The broken pipe most likely is just one of the casualties of rust and corrosion. even though something is rusted it still has to come off.
the oil in the radiator this could be from a leaky oil cooler or a leaky trans cooler.NOT his fault.
the steering leak prob his fault. the loose wires on the starter his fault. he should be willing to work with you and fix the car . but the money is his call if you don,t get what you want or no help from him. you may need to choose the legal path
Aug 13, 2010 at 3:25 PM
