The water pump wnet out so wechanged it and the timing belt at the same time as recommended. We were careful to make sure that all pulleys and the marks on the timing belt wre aligned as the Haynes manual said to do. The care will crank but it will not start. If we moved a pulley while installing the timing belt can the timing be adjusted or do we have to take the car apart again and start over. Or is this not the problem? The car started right up each time before we did the repairs to the water pump and timing belt change. Help in Texas!
SPONSORED LINKS
Sunday, July 6th, 2008 AT 10:52 PM
