Hi WDDAVILA,
Possible the connections to the coil are loose or contaminated. Unplug them and look for contamination or corrosion.
Spray some rust remover to clean them up. If the pins are loose, you need to make them tight again.
Check for internally broken wires near the point you were fiddling with.
SPONSORED LINKS
Sunday, June 22nd, 2008 AT 3:52 AM
