Engine Cooling problem
1993 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic
how do you tell if it is the water pump that has the problem?
Sunday, November 2nd, 2008 AT 12:43 PM
BLACKOP555
MECHANIC
Basically remove it for visuall inspection you can also pinch the upper hose with the engine running and see if it builds pressure and you can feel water rushing past the upper hose.
