So for a around a year and a half now, I have had a random coolant leak. It leaks onto the ground under the engine. I cant find exactly where the leak is comming from. Sometimes it will leak alot, then it will go months and months with no leaking at all. It seems that when i run my car for a long time it will leak when i stop the car. I just an not sure how serious this is and if it is something I really need to be worried about. It has been like this for over a year and i need to do more extensive traveling. So what should I do. i dont want to get ripped off. Thank you for any advice you can give.
Jan 6, 2008 at 9:13 AM
