backup/stop light switch 1995 Rodeo
1995 ISUZU
ISUZU
On a 1995 isuzu rodeo 150,000k miles 3.2 engine, manual transmission, I have a problem with the backup lights.
They stay on in forward gears. They will come on in reverse as they should also.
Is this a switch problem and if so where is the switch and what manufactor do you recomend for a replacement switch?
I would also like to know which is the correct part name. I 've heard this switch refered to as both a backup light and stop light switch. Are they the same?
Feb 9, 2007 at 2:26 AM
NORM SANSON
Your stop is your red brake lights, activated by a switch on your brake pedal, and is nothing to do with the backup light, usually referred to as a reverse light.
The reverse light is activated by a switch on the right side of the gearbox, an ISUZU part, which can be disconnected from underneath the vehicle, a plug near the switch, if you want to stop it from remaining on. :)
Mar 7, 2007 at 8:14 AM
