trooper lights come on at 35 degrees F
1935 ISUZU
BILLTOCCO77
1999 trooper. the head lights come on their own when the temp drops below 35. Any leads would be greatly appreciated.
Jan 25, 2007 at 5:18 PM
SERVICE WRITER
  • 9,123 POSTS
There are similiar problems that I have like yours. OFten it was a contact that would move from the cold. I would try swapping the relay with another one of the same to see if it stops-but watch for problems on the other circuit, may be in the comibination switch also. I don't know that this will work, but worth a try. Take a hairdryer and run it over the suspected areas when this problem is happening. You don't want to "cook" anything, but warn it. The combination switch may take a little longer to react if it is the problem as it is buried and protected from the column. The relay would be easy to check this way.
Jan 25, 2007 at 10:04 PM
