1998 Isuzu Rodeo No Shift and Lights Out
1998 ISUZU
CATHBATTLE
I have a 1998 Isuzu rodeo 130,000 miles. first my left single light would not turn off or work. now when i start my engine i can't put in reverse or drive the car has to be turned off. now my dash lights and outside back lights will not come on.
Dec 22, 2006 at 11:27 PM
2CARPRO JACK
  • 11,533 POSTS
Check the fuses. 98 should have a shifter lock in it(assuming its an automatic). There sounds like a power feed problem. Check all grounds and power feeds under the hood as well as the under-dash fuse box
Dec 23, 2006 at 12:45 AM
Suggested Repair
Check all fuses, grounds, and power feeds under the hood and in the under-dash fuse box. A power-feed problem may also affect the automatic shifter lock.
Conversation Summary
The owner of a 1998 Isuzu Rodeo reported a left light that would not turn off or work, then could not select reverse or drive unless the engine was off. Dash and rear lights also failed. The expert advised checking fuses, grounds, and power feeds under the hood and in the under-dash fuse box, noting a possible shifter lock and power-feed problem.
