2000 Isuzu Rodeo Oil Consumption
2000 ISUZU
SHAUN_1213
Hi my name is Shaun. I have a 2000 Isuzu Rodeo and every week I have to put oil in. When I check the dip stick it is dry. There are not oil leaks and I also checked to see if maybe leaking oil from the exhaust and no it is not. Any ideas whats going on with my car
Apr 10, 2006 at 10:57 AM
LOSONE
  • 1,616 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year, engine, transmission and mileage of your car.
Apr 10, 2006 at 11:11 AM
SHAUN_1213
Model Isuzu Rodeo. Year: 2000 100000KM. 3.2L v6 engine. transmission is standard..
Apr 10, 2006 at 11:29 AM
JOUGH626
  • 55 POSTS
I had the exact same problem. No leaks, great compression, no black/blue smoke. I replaced the PCV Valve and installed a new Oil Pressure Sensor. It seems to be drinking alot less oil now. I hope this helps you too.
Jun 17, 2006 at 10:32 AM
Suggested Repair
Replace the PCV valve and install a new oil pressure sensor, which resolved similar unexplained oil consumption with no visible leaks or smoke.
Conversation Summary
The owner of a 2000 Isuzu Rodeo with a 3.2L V6 and standard transmission reported adding oil weekly despite a dry dipstick and no visible leaks or exhaust oil. An expert with the same symptoms, good compression, and no smoke said replacing the PCV valve and oil pressure sensor reduced oil consumption.
