'00 Amigo transmission engagement problems & fuel gauge
2000 ISUZU
JACKREECE
2000 Isuzu Amigo, V6, 4x4, Automatic transmission, 78000 miles
Transmission engages slowly, meaning it doesn't immediately go into drive when placed there. Will also slip out of drive into neutral (or at least fail to engage) when starting out from a stop - IF driver notices and eases up on the gas, it will drop back into drive - if not, it will buck & shudder until it finally engages...(think "neutral drop" and you get an idea of what it feels like) Ideas? Also tranny service procedures? (nothing in the owner's manual)
Fuel gauge will correctly register a completely full tank of gas, then after 35-40 miles, gauge drops below empty and the "fuel" light starts flashing - anyone have any ideas on this one either?
Thanks guys!
Jan 20, 2006 at 11:40 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Provide any existing diagnostic findings for either complaint and clarify whether either problem was eventually resolved.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
99AMIGO
Hey, I have a 1999 Amigo and I had a similar problem with my fuel gauge. After filling up only the first 7 gallons would register and after that my gauge would show empty. I eventually change the fuel sending unit, which normally corrects the problem. (It didn't fix mine, per se, the gauge now sits at half full) I am going to go back in and see what else it could be.) But normally that is one of the first things that is checked or replaced. I attaced a link that discusses changing the fuel sending unit. Good Luck.
Feb 5, 2006 at 7:40 AM
VGROBERTSON
We are needing to replace the clutch in the amigo, however my husband has never replaced a hydraulic clutch, could you help him with providing some information, especially a diagram for him to review.
Thank you
Mar 11, 2006 at 7:12 AM
Discussion summary
The owner of a 2000 Isuzu Amigo V6 automatic reported delayed engagement in Drive and bucking or shuddering when pulling away. They also reported that the fuel gauge fell from full to below empty after about 35 to 40 miles, with the fuel light flashing.
Reported outcome: The original owner did not report a completed repair or resolution of either complaint.
A different participant described replacing a fuel sending unit on a 1999 Amigo without restoring a correct gauge reading. That separate experience does not establish the cause or repair for this vehicle. The thread does not establish whether the two original complaints are related.
Read the original discussion
