Issues with acceleration and other issues?
191,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DAVID WININGS
I was driving and my engine was sputtering so I safely stopped and could not find the issue, it rattles when the gas is pushed, it also smokes when the throttle is pushed, I don't know what the issues is whatsoever.
Jul 30, 2023 at 12:36 AM
  • 55,721 POSTS
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. It sounds like you have a fuel pump that is going out or a clogged catalytic converter. I would start by changing the fuel filter. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
and this guide as well, you can rent a fuel pressure gauge at the auto parts store:
FUEL PRESSURE
At idle:
Approximately 235 kPa (2.4 kg/sq.cm, 34 psi)
A few seconds after ignition switch is turned from OFF to ON:
Approximately 294 kPa (3.0 kg/sq.cm, 43 psi)
Here is a guide to help you check the cats.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
also, we should run the codes.
Please go over these guides and get back to us.
Jul 31, 2023 at 4:53 AM
