Okay, I have the car listed above that has sat for to years because of ignition problem. I replaced ignition,ignition coils, fuel pump, starter, and all six injectors. I try to crank it and it is a slow crank, but if I crank it for about twenty seconds it tries to fire up but does not. is it because my battery is low and is not cranking the starter fast enough to make everything work faster and stronger? Please I need help.
Feb 22, 2017 at 1:53 AM
