1990 Nissan Maxima battery replacement triggers alarm
172,000 MILES • 6 CYL • 2WD • MANUAL
JLEE4171
I have replaced the battery on this car many times but never had such an issue; today when I tried to put in a new battery, after I first connected the positive cable, then the negative cable, after about 30 seconds or so (to put away my tools), the alarm went off when I turned the key and tried to start the car. I don't have an alarm remote control so I don't know how to turn it off. I turned the key to "iginition" but it did not work. Can you let me know how to correct this problem/
Thank you very much.
Regards,
Jason
Jun 8, 2008 at 12:48 PM
KHLOW2008
  • 41,812 POSTS
Hi jlee4171,
There are many types of alarm system and I do not know which is incorporated in your car so I can only offer the following different possibilities.
1. Locate for a reset button. Turn Ignition on and press reset button.
2. Turn ignition on and off 5 or six times in succession.
4. Disconnect alarm control unit. Turn ignition on and plug alarm unit back.
Good luck.
Jun 9, 2008 at 3:16 AM
