Battery Replacement ?
200,100 MILES • 6 CYL • 2WD • AUTOMATIC
SADANANDMBA76
if i fix wrong specification battery in my car what will happen?
Aug 2, 2010 at 3:42 AM
SQM
  • 6,383 POSTS
It is important to use the correct size and specification battery when finding a replacement.
https://www.2carpros.com/articles/how-a-car-battery-works
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
If the battery does not have enough cold cranking amp then you could have starting issue. It might not start the vehicle or can have hard time starting.
If the battery dimension is incorrect you cold have fitment issue. Also if it is too tall it can hit the hood which can lead to issues.
Sep 3, 2021 at 5:44 AM
