I don't think it is the crank shaft sensor because once the van starts it continues to run with no issues. The problem may not surface again for several days and will turn over and start instantly. Then for no apparent reason when you go to start it the engine will turn over and will not fire to start running. If you let it sit for half an hour it will start right up.
Can't get anyone to fix it because they can keep it overnight for a few days and it will start right up with no hesitation. They van runs great, doesn't miss or stall and keeps going until you shut it off, then it may start the next morning or it may not. The van is too good to get rid of it, but not reliable in case of an emergency. Do you have any other suggestions. I read that it could maybe be a door relay going bad. It doesn't seem to be the neutral safety switch either because changing gears from park to neutral and back doesn't make a difference either. What do you think. Thanks for any suggestions. Jim
Jan 20, 2019 at 10:25 AM
