1995 infinity G-20
1995 INFINITI
BPINGI
mileage 132,000 - Car starts and runs cold, after shut off warm won't start. lights on dash are on, but starter will not engage. Jump start (Manual trans) and runs fine - could it be battery short or what to check. Do not even see whrer starter is on it.
Sep 9, 2007 at 6:47 AM
  • 75,988 POSTS
[quote:12c3eda409="bpingi"]mileage 132,000 - Car starts and runs cold, after shut off warm won't start. lights on dash are on, but starter will not engage. Jump start (Manual trans) and runs fine - could it be battery short or what to check. Do not even see whrer starter is on it.[/quote:12c3eda409]
At the clutch pedal theres a switch there jump the wires if it starts the clutch switch is bad. but 1st check for power one of the wire should have battery voltage when key is at start position-no voltage its coming from the ignition switch. Voltage going thru the clutch switch-check the starter relay or the starter itself.
Sep 10, 2007 at 11:50 AM
