Infiniti G20 CV Joint Click and Pull
BRYANBEERS
I know the front axles need changed because i hear the clicking noise when i turn. would bad axles/cv joints make the car ride rough? i have also noticed that when i go over a slight bump or like a dip or something at a 40+ the steering wheel will slightly pull to one side or the other. is that due to the bad axle/cv joints?
Apr 3, 2006 at 9:36 AM
LOSONE
  • 1,616 POSTS
If Bad CV joints have excessive play and it will make the car pull one way or the other depending on the torque of the engine. Make sure you replace then soon. They could lock and/or damage the transmission due to the inbalance.
Apr 3, 2006 at 10:24 AM
Suggested Repair
Replace the worn front CV axles soon. Excessive joint play can make the car pull with engine torque, and a failing joint can lock or damage the transmission from imbalance.
Conversation Summary
The owner of an Infiniti G20 hears clicking when turning and plans to replace the front axles. They ask whether bad CV joints cause a rough ride and a slight steering pull over bumps at speed. The expert says excessive CV joint play can pull the car one way or the other depending on engine torque and advises replacing the joints soon so they do not lock or damage the transmission.
