Infiniti G20 Seat Won't Move Forward or Back
INFINITI
GTHARR58
Infiniti - G20 - The driver side seat stop working. the level which makes the seat go forward or move backward stop working, it still rises up and down. what should i check the fuses first because i do not want to take it to the dealer and they ripe me off like always. i am a helpless female which knows nothing about cars other than drive and gas it. thanks
GT [color=black][/color]
Jan 17, 2006 at 9:45 AM
2CARPRO JACK
  • 11,533 POSTS
Need to check for power and ground at the motor that controls that movement in the seat. Could be motor, switch, or cable from motor to seat
Feb 7, 2006 at 9:07 AM
Suggested Repair
Check for power and ground at the seat motor that controls forward and backward movement. The fault may be the motor, the switch, or the cable between the motor and the seat.
Conversation Summary
The owner of an Infiniti G20 reported that the driver seat no longer moves forward or backward, although the up-and-down function still works, and asked whether the fuses should be checked first. The expert advised checking power and ground at the motor for that movement and said the cause could be the motor, switch, or cable.
