1995 Infiniti G20 Warm No-Start
At the clutch pedal theres a switch there jump the wires if it starts the clutch switch is bad. but 1st check for power one of the wire should have battery voltage when key is at start position-no voltage its coming from the ignition switch. Voltage going thru the clutch switch-check the starter relay or the starter itself.
Suggested Repair
Check the clutch pedal safety switch and start-circuit voltage first. With the key in start, one clutch-switch wire should have battery voltage; if not, trace the circuit back to the ignition switch. If voltage is present through the switch, jump the switch wires—if the engine then cranks, replace the clutch switch. If the switch tests good, check the starter relay and the starter.
Conversation Summary
A 1995 Infiniti G20 with a manual transmission starts and runs when cold, but after a warm shutdown the dash lights come on and the starter will not engage. A jump start gets it running again. The expert advised checking for battery voltage at the clutch switch with the key in start, jumping the switch wires to test it, and then checking the starter relay or starter if voltage is present.
