HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Infiniti
G35
Engine
Symptoms
Overheat
SPONSORED LINKS
Engine overheating?
PREV
1
2
NEXT
CARMAN8212
MEMBER
Had the problem before with air being trapped just dont rmr how to release air out of the lines near heater core
Thursday, November 1st, 2018 AT 6:32 PM (Merged)
MECHANIC
Air will bleed itself over time. You still need that leak down test
SPONSORED LINKS
DAVID INMON
MEMBER
1 POST
2003 INFINITI G35
3.5L
6 CYL
AUTOMATIC
180,000 MILES
I have replaced water pump and thermostat it over heats when I turn on the air conditioner within five minutes of turning on air conditioner.
HMAC300
MECHANIC
Check cooling fan fuses and relays under hood the one for air conditioner may not be kicking on then have it checked for a head gasket problem.
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Overheat Content
An Overheating Issue Possibly Related An Engine Or...
My Issue Started This Summer. My Coolant Ran Low. I Topped It Up With Prestone 50/50 Mix. Used The Car In The City For Around A Month And...
Asked by
Sanj
1 ANSWER
2004
INFINITI G35
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Leak
I Just Noticed A Leak. Some Brownish Liquid In The Front Of My Car. Upon Further Inspection I Noticed Under The Hood Some Liquid Pooling In...
Asked by
Quennel Hill
1 ANSWER
2008
INFINITI G35
Engine Not Starting?
Today, While I Backed Up And Shifted To Drive Mode My Car Just Died. While In Drive Mode And Engine Running Car Would Not Move. I Turned It...
Asked by
o_tsib
24 IMAGES
2005
INFINITI G35
Vehicle Doesn't Accelerate. Low On Power
My Infiniti Is Having An Accelerating Issue That I Cant Find Out What The Issue Is. About A Month Ago I Notice That When I Started The Car...
Asked by
serranasj
2 IMAGES
2004
INFINITI G35
Oil Leak
I Am Told That The Leak In My Ifiniti G35 Is The Oil Filter Adapter Gasket. How Much Should This Replacement Cost?
Asked by
kharvey
1 IMAGE
2004
INFINITI G35
VIEW MORE
SPONSORED LINKS
Coolant Leak Symptoms
Online car repair manuals
