I have replaced the pick-up under the distributor cap, the MAP sensor, TPS , O2 sensor, new thermostat (190), EGR valve, replaced bad radiator, reset all codes (remove negative battery terminal - key on ten seconds -replace battery cable- codes now 11,12, 55), when I am stuck in stop and go traffic ( almost everyday on the way home) the engine will die -no restart for forty five to sixty minutes minutes, water temperature gauge in dash is normal. going down the road at highway speeds the engine purrs great, plenty of power pulling up hills, no need to downshift. any advice as to what the problem might be would help.
Dec 16, 2016 at 11:16 AM
