1995 Dodge Dakota truck dies when 4wheel engaged
KAPASA
  • 1995 DODGE DAKOTA
  • V8
  • 4WD
  • 118,000 MILES
Truck engine dies when 4 wheel engaged
Sunday, December 14th, 2008 AT 1:45 PM
  • 109,885 POSTS
Hi:
There are several vacuum lines that operate the 4wd. You need to check them. Most likely there is a major leak. Have someone put the truck in 4wd while you listen for a hissing from the under side of the truck. Also, there are 4wd vacuum lines on the passanger side near the back of the engine. Make sure they are ok and the hard (small) plastic lines that go into the stardard rubber hoses are not melted from heat or cracked.
One question, if you keep your foot on the gas, can you keep it running?
Monday, December 15th, 2008 AT 6:06 PM
KAPASA
No, the truck dies when we put it in 4WD.
Monday, December 15th, 2008 AT 10:11 PM
  • 109,885 POSTS
Hi Again:
Listen, there is nothing electrical that can shut the engine down when you go to 4wd. It has to be vacuum related, or the linkage it hitting someting. Check for those things and let me know what you find.
PS: I have a 94 and will check it to see if there is anything I can identify.
Tuesday, December 16th, 2008 AT 2:57 PM
