in exceleration no power even when you floor it
1.9L • 4 CYL • 2WD • AUTOMATIC
CATHYMDAVIS
The car idles good but when you go to excelerate it like has no power even if you pump the decelerator or floor it.
Mar 17, 2015 at 5:19 AM
JDL
  • 16,098 POSTS
If this is a high mileage engine, I'd have to check cylinder compression, if compression is very poor, You may have a tough time trying to get it to run like you want it, without engine overhaul.
How long since a tune-up? Fuel pressure ok, air filter, fuel filter. Make sure no pressure on system if changing fuel filter. Can you check for applicable trouble codes, just in case there are any?
You can check throttle position sensor, clean throttle-body and idle air.
Mar 17, 2015 at 5:39 AM
JDL
  • 16,098 POSTS
Just to add if it idles good, idle air should be ok.
Mar 17, 2015 at 5:40 AM
