Ignition switch connector
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
What is the best way to replace the ignition switch connector? Do I need to solder it or clamp it?
I know there is a bad connection there. Today check engine came on. Codes p0882, p0714, p0218 only show up in summer time.
Thank you
Jun 24, 2018 at 12:36 PM
Good morning again.
Solder and shrink wrap is the best way to ensure a good connection.
Are you replacing the pigtail or just one wire?
Jun 24, 2018 at 10:14 PM
ZEMORZEMOR
  • 486 POSTS
I am replacing the wire and the connector and pins.
Jun 24, 2018 at 10:58 PM
Check and see if you can get a pigtail. That is a new connector and wires. All you have to do is solder and shrink wrap to the existing harness.
Jun 24, 2018 at 11:05 PM
ZEMORZEMOR
  • 486 POSTS
Yes, it is what I have. Thanks
Jun 25, 2018 at 12:13 AM
Good deal. Make sure you shrink wrap the joint after you solder it. Butt connectors will not work. They will overheat from the current draw cause a voltage drop.
Once you are finished. Then drive it and see if any codes return.
Jun 25, 2018 at 4:25 AM
ZEMORZEMOR
  • 486 POSTS
Okay, I will do.
Jun 25, 2018 at 5:42 AM
ZEMORZEMOR
  • 486 POSTS
Oh, I forgot to tell you the PCM was replaced two years ago. The p0882 always triggers when starting this engine.aka vehicle speed 0 mph. Also, I replaced filter and transmission oil two weeks ago. However, the codes were there before transmission fluid replacement.
Jun 25, 2018 at 5:51 AM
Okay, let's cross that bridge after you replace the connector. You may have a voltage supply issue that is causing those codes.
Jun 25, 2018 at 6:15 AM
ZEMORZEMOR
  • 486 POSTS
I replaced the connector solder the wires and heat shrink them. P0218 came back I think not sure, only when the AC is on. when I turn the AC on I checked the coolant temperature with code reader it was 221 and kept climbing. I did not hear the high speed fan turns on. Only heard the fan running one speed.
Jun 26, 2018 at 5:43 AM
If you turn on the AC does the high speed work on the cooling fan?
Did you replace the thermostat?
P 218
P0218
Item Description
Symptom/DTC P0218
Descriptor
High Temperature Operation Activated
Probable Causes
Cooling System Operation
Operating in Limp-Home Mode
Torque Converter Clutch (TCC) Not Engaging Properly
Transmission Oil Cooler Plugged
Jun 26, 2018 at 6:06 AM
ZEMORZEMOR
  • 486 POSTS
Yes, the fan turns on but does not seem it is high speed. I just jumped the fan pig tail. I jumped the middle pin ground with the right pin fan turned on. After jumped ground with left pin fan turned on, however they seems they are same speed.
Jun 26, 2018 at 6:16 AM
Check the dark blue/orange wire for power. that is the high speed motor control. It comes for the TIPM. If it has power, then the fan motor is bad. If it does not then the TIPM is bad.
Jun 26, 2018 at 6:20 AM
ZEMORZEMOR
  • 486 POSTS
There are two relay on top of fan. When AC on both relays are closed. I guess the high speed in this car and fan is running I did not check yet at the fan harness if there are power in both wires.
Jun 26, 2018 at 8:41 AM
Check the powers per the diagram I sent you and let me know.
Jun 26, 2018 at 8:46 AM
ZEMORZEMOR
  • 486 POSTS
The car fan is 3 pins and the diagram has 4. Also, in the diagram is not showing relays which I have in car.
Jun 26, 2018 at 8:49 AM
Are the colors right at the fan? The ground is the way it is mounted.
Is this a turbo or non turbo?
Jun 26, 2018 at 9:05 AM
ZEMORZEMOR
  • 486 POSTS
Non turbo. I cannot see the colors there are some burn marks.
Jun 26, 2018 at 9:06 AM
Check the connector on the fan for any damaged or burned wires. Test the wire I told you for power.
Jun 26, 2018 at 9:08 AM
ZEMORZEMOR
  • 486 POSTS
There is burnt wire harness side not fan side they are thick wires.
Jun 26, 2018 at 9:10 AM
Can you post a picture?
Did you check the voltage?
Jun 26, 2018 at 9:12 AM
ZEMORZEMOR
  • 486 POSTS
Inside the connector is black aka burnt. I did not check voltage I think needs to be replaced, spliced or something else.
Jun 26, 2018 at 9:15 AM
ZEMORZEMOR
  • 486 POSTS
I measured the temperature of the transmission with infra red thermometer. Today outside temperature is 100 F.
Oil pan temperature 157.
Transmission casing temperature by the engine block 212.
Oil cooler temperature 180.
Jun 27, 2018 at 10:35 AM
Can you post a picture of the connector?
Jun 27, 2018 at 10:56 AM
ZEMORZEMOR
  • 486 POSTS
I need to jack the car up. My other significant took the car when I have chance I will sir. Are the temperatures good?
Jun 27, 2018 at 10:58 AM
ZEMORZEMOR
  • 486 POSTS
Here is the pictures.
Jun 28, 2018 at 6:59 AM
ZEMORZEMOR
  • 486 POSTS
Here is the pictures. The tab inside that hold the pin is broken. I went to the junk yard and replaced the harness. It has two relays and two connectors.
Jun 28, 2018 at 7:02 AM
Those connectors are no good. They are burned up from high resistance.
Is that the original or the replacements?
Transmission fluid temperature is a bit high. Wondering if the cooler may be restricted.
Jun 28, 2018 at 9:36 AM
ZEMORZEMOR
  • 486 POSTS
That was the old one. The new one aka junk yard ones are good and shiny. Yes, the code came back today. It is hot day too as yesterday 98F. How to check the transmission oil cooler?
Jun 28, 2018 at 12:40 PM
Is the cooler external or inside the radiator?
what code returned?
Jun 28, 2018 at 9:48 PM
ZEMORZEMOR
  • 486 POSTS
It is external mounted in front bottom of radiator.
Jun 28, 2018 at 11:19 PM
It would need to be flow tested by someone to be sure there is no restriction. It would be cheaper to replace it than have it checked.
Take the temperature at the top and bottom and see what the temperature difference is between the two test areas.
Jun 29, 2018 at 12:52 AM
ZEMORZEMOR
  • 486 POSTS
At the top where the rubber hose meets the cooler the temperature is 136 at the bottom where the rubber hose meets the cooler temperature 110. Today's temperature 72.
The code that returned is p0218.
Jun 29, 2018 at 2:02 AM
P0218
Item Description
Symptom/DTC P0218
Descriptor
Probable Causes
The temperatures are not enough change. I would start by replacing the transmission cooler.
Jun 29, 2018 at 2:18 AM
ZEMORZEMOR
  • 486 POSTS
When I wiggled the PCM connectors p0882 came back and car went to limp in mode.
Jun 29, 2018 at 3:36 AM
Okay, remove the connectors and clean them. Make sure there are no dirty or damaged pins. Use electrolytic grease on the pins for a better connection and retets.
Jun 29, 2018 at 6:29 AM
ZEMORZEMOR
  • 486 POSTS
Forgot to tell you, when the car went to limp mode security light was flashing airbag light on and all gears were selected on dashboard. After I pushed in connector the car is good the only code left is po218. I will do what you told me.
Jun 29, 2018 at 6:35 AM
Okay, clean the connection and see what happens.
Jun 29, 2018 at 6:42 AM
ZEMORZEMOR
  • 486 POSTS
Can you please tell me where the transmission temperature sensor is located?
Jul 1, 2018 at 1:02 PM
Removal:
The valve body assembly must be removed to gain access to and replace the transmission range sensor.
1. Disconnect the battery cables.
imageZoom/Print
2. Remove air cleaner assembly (1).
imageZoom/Print
3. Remove the battery hold down clamp and remove the battery (1).
imageZoom/Print
4. Remove the battery tray (1).
imageZoom/Print
5. Disconnect gearshift cable (1) from manual valve lever(2).
6. Remove manual valve lever.
7. Disconnect transmission range sensor connector.
8. Hoist vehicle.
imageZoom/Print
9. Remove oil pan bolts (1).
imageZoom/Print
10. Remove oil pan (1).
imageZoom/Print
11. Remove oil filter (1).
imageZoom/Print
12. Remove the valve body-to-transaxle case bolts (1).
imageZoom/Print
13. Remove park rod rollers (1) from guide bracket (2) and remove valve body from transaxle.
imageZoom/Print
14. NOTE: To ease removal of the valve body (1), turn the manual valve lever fully clockwise to low or first gear.
CAUTION: The valve body manual shaft pilot may distort and bind the manual valve if the valve body is mishandled or dropped.
imageZoom/Print
15. Remove manual shaft seal (2).
imageZoom/Print
16. Remove TRS retaining screw (3).
imageZoom/Print
17. Slide Transmission Range Sensor (1) up the manual shaft and remove.
Jul 1, 2018 at 9:39 PM
ZEMORZEMOR
  • 486 POSTS
How did the transmission cooler get clogged up? I have seen a video showing someone was cleaning cooler using a machine and in the filter was like metallic particles.
Jul 2, 2018 at 1:24 AM
