Ignition problem
3,010,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ANTHONY WARE
The truck cranks and runs fine then sometimes when you turn it off it cranks but will not start. the fuel pump will not come on, but you can turn key on and off three or four times and fuel pump comes on and it will start. When you turn key on all gauges work fine.
Dec 31, 2017 at 3:39 AM
Good afternoon.
It sounds like the fuel pump motor has a bad spot in it. It may have to be replaced due to this. The other possibility is the connector at the pump itself. in the winter it is exposed to the outside environment.
May 31, 2021 at 5:40 AM
ANTHONY WARE
I changed the fuel pump relay it cranked every time until i went to town and turned it off, then it did it again but after bout three tries pump came on and cranked, but was not thinking fuel pump because if it cranks i can drive four hours without a problem .
Once the fuel pump runs it will stay running until shut off and commanded on again. Sounds more like the pump is failing.
ANTHONY WARE
You was right on it was the fuel pump.
good, glad to hear you got it fixed.
