no fuel pressure
2001 FORD F-150
RICHTERGROUP
Engine Mechanical problem 6 cyl Two Wheel Drive Automatic
My sons 2001 F150 has no fuel pressure. I have checked the relay and fuse, inertia switch and filter. All are fine. I disconnected the fuel line from the filter and turned the ignition on and no fuel pumps out. I hear a brief noise in the tank as if the pump starts and then stops. My question... is there any thing else I should try and/or check before dropping the tank and replacing the pump, which I had already replaced 7 months ago. I would really appreciate any help I can get.
Jul 9, 2010 at 7:32 AM
  • 110,244 POSTS
Are you sure the filter isn't plugged? Also, (and don't get mad at this question) are you sure there is fuel in the tank?
Jul 9, 2010 at 1:51 PM
RICHTERGROUP
I blew through the filter with no restriction. I asked my son the same question regarding the gas, and yes, he filled it up 5 days ago and it now reads 3/4 tank. Should gas pump out with the hose disconnected and turning on the ignition?
Jul 9, 2010 at 2:06 PM
  • 110,244 POSTS
Yes, it should spray out. I would have to double check, but it should produce around 50PSI. If you have power to the relay and it is working, either you have a broken wire to the pump, a bad connection at the pump, or the pump itself is bad.
Jul 9, 2010 at 6:06 PM
RICHTERGROUP
Ok, I'll drop the tank and inspect the wiring, etc. Is there any way to test the pump prior to purchasing another one, just to make sure?
Jul 10, 2010 at 3:47 AM
  • 110,244 POSTS
When you remove the tank, ground it and check to see if the pump is turning on. If it is, disconnect the fuel line and see if any fuel is coming out. Actually, before you remove the tank, disconnect the fuel line before the filter. Fuel should pump straight out from the supply line.
Let me know what you find.
Jul 10, 2010 at 5:19 AM
RICHTERGROUP
Hey Joe,
It ended up being a defective pump. Thanks for the help!!!
Jul 12, 2010 at 9:03 AM
  • 110,244 POSTS
Glad you found the problem. Let us know if you have questions in the future, and thanks for using 2carpros.com.
Jul 16, 2010 at 2:07 PM
