Ignition module location
177,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
BUSTER HARTLEY
My car does not have a distributor so I do not know where the ignition module is.
CODE:P1300 ECM
Sep 3, 2017 at 3:18 PM
CARADIODOC
  • 34,414 POSTS
You have two ignition coil packs that each fire two spark plugs at the same time. Each one has an ignition module built into it. They are at the rear of the engine. You have probably found those already. They are triggered by the engine computer which is under the center of the dash.
Sep 3, 2017 at 4:21 PM
