Idle and driveability issues
  • 52,797 POSTS
Did you reply? I got a notification but nothing came up.
Tuesday, September 24th, 2019 AT 8:05 AM
LANCE GAGNE
  • 34 POSTS
Nope will keep you posted after I change pump. Will be a few days. Thanks for being patient with me.
Tuesday, September 24th, 2019 AT 2:07 PM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Tuesday, September 24th, 2019 AT 2:43 PM
LANCE GAGNE
  • 34 POSTS
Wouldn't let me reply on my phone. Weird. Anyway I changed the pump today. Initial pressure was around 65 psi with the same check, ignition on, engine off, pump initialized. Better for sure. Also noticed a lot more pressure when release was pushed now than before. A lot more gas comes out. Before wasn't much. I will drive for a day or two and check it again. On a side note: my pressure reading from my obd2 still said 399 kpa while idling. Could I have a bad fuel pressure sensor as well? I did change entire pump with a new fuel tank pressure sensor. Did not want to drop that tank again if it went bad, lol.
Sunday, September 29th, 2019 AT 5:44 PM
  • 52,797 POSTS
Drive it and see what happens and then let me know.
Monday, September 30th, 2019 AT 2:24 AM
LANCE GAGNE
  • 34 POSTS
Seems to be driving normally now. No surges, or low idles. Guess it took a couple days to adjust to the new pump. I'll post if I have any other issues with it but seems like it should be good now. Thanks so much for your help Roy! Good to know there is a place to go for the shade tree diy'er to get help from the pros!
Thursday, October 3rd, 2019 AT 3:43 PM
  • 52,797 POSTS
You are welcome.
Thursday, October 3rd, 2019 AT 3:54 PM
Related Air Intake Tube Boot Replace/Remove Content
Air Intake Boot Replacement
VIDEO
