IAC swap
200,060 MILES • 3.8L • V6 • 2WD • AUTOMATIC
CHRIS KINARD
  • 97 POSTS
Hello, i got a 2004 mustang bought it for parts for my car listed above. i took off the IAC on the 2004 and put it on the 2000 and it runs better, smoother i can go faster when i'm doing 75 the engine is purring like a cat, lol. anything i need to know about this please. lmk bad idea good um etc. thank you i appreciate y'all a lot awesome pepps in my book!!!
Also, can I use the 2004 air intake manifold to put it on the 2000?
Aug 28, 2020 at 2:16 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
There looks to be only a slight difference between the two idle air control valves. I've attached 2 pictures below showing the difference. I've circled in red the only difference I found which is the clocking for the wire plug connection.If you want to use your phone to take a picture and upload here the air intake manifolds I could see what they look like.Hope this helps and thanks for using 2CarPros.
Aug 29, 2020 at 4:20 AM
