I replaced two fuses under the hood and now the starter will not kick in to start. Battery is full all lights bright.
Sunday, July 2nd, 2017 AT 7:23 PM
CARADIODOC
MECHANIC
Which fuses? Does the ignition switch have to be turned on for the fuses to blow? What is the symptom? Does the starter crank the engine, and the engine will not run, or is it the starter that is gone out? What have you checked so far, and what were the results?
Sunday, July 2nd, 2017 AT 7:52 PM
JR SIMPSON
MEMBER
1 POST
I got it fixed I had a starter or ignition fuse blew. It was a pink 30 amp in the power box under the hood. Thanks for your support
Tuesday, July 4th, 2017 AT 9:00 AM
CARADIODOC
MECHANIC
Happy to hear you solved it. Come back and see me when you need my wondrous wisdom!
