Firing order needed?
TRUCKER666
  • 7 POSTS
Ok blow air with compressor or mouth. Never heard that one but will try. Just put a hose into the hole and if u can blow air its not tdc. Right
Tuesday, October 20th, 2020 AT 1:04 PM (Merged)
PETELILLY
  • 1979 CHEVROLET TRUCK
  • V8
  • MANUAL
  • 85,000 MILES
I changed my plugs, but I may have gotten them out of order. I tried to pull one and replace one, but I had taken off two, before I decided to go one by one. I just want to make sure they are in the right order.
HMAC300
  • 48,601 POSTS
The firing order is 1-8-4-3-6-5-7-2 the number one position is 11:30 on the distributor cap. That's looking from the driver's seat. The distributor turns clockwise. That should get you going.
WRENCHTECH
  • 20,761 POSTS
How about telling us what engine you have here?
TRUCKER666
  • 7 POSTS
Ok its a 305. When I pulled the distribuator out I did not have it on tdc. Then I found tdc put dist. Back in with rotor pointing at no1. Still nothing. Then changed coil, nothing then replaced module, nothing. All it dose is turn over and puffs out of the carb. Could it b out by 180?
WRENCHTECH
  • 20,761 POSTS
Sure it could be if you didn't make sure it was TDC on the compression stroke. Most people just hold their finger over the spark plug hole while rotating the engine and you will feel the compression when you're approaching #1 TDC.
TRUCKER666
  • 7 POSTS
I just put the line on the balacer in the middle of the marks then check with a srudriver but feels like there is still a small gap on top of piston. Is this wrong
WRENCHTECH
  • 20,761 POSTS
You still need to know that you are on the compression stroke or you will be 180 out. The crank rotate 2 times to every one revolution of the distributor.
TRUCKER666
  • 7 POSTS
Ok I see.I, ll try that finger over the hole trick. Thanks for the info.
