Gas gauge not reading properly after replacing fuel pump
69,000 MILES • 4.6L • V8 • 2WD • MANUAL
MUSTANG2002
My car starts and run fine but the fuel gauge reads a quarter tank of gas , but I only have a gallon of gas I put back in the car. Could I have a grounding issues? How do I reset or re-calibrate the fuel pump setting?
Jan 20, 2018 at 9:39 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It sounds to me as though you may have bent the float arm when replacing the fuel pump.
I assume the fuel level was find before?
Jan 20, 2018 at 11:01 PM
MUSTANG2002
Yes it was always accurate until I replaced the fuel pump. so I should not pay someone to so call regrouped or re-calibrate the fuel pump ? Just pull the pump back out and recheck the float arm.
Jan 20, 2018 at 11:09 PM
MUSTANG2002
Thank you for your help and support.
Jan 20, 2018 at 11:13 PM
