Fuel pump and fuel filter replacement
102,000 MILES • 4.6L • V8 • RWD • MANUAL
BULLITT5123
How to replace these two properly. Thank you.
Oct 7, 2016 at 9:10 AM
WRENCHTECH
  • 20,760 POSTS
The fuel pump is inside the tank and the tank has to be removed to access it. http://i1198.photobucket.com/albums/aa448/Wrenchtech/87563684.gif The fuel filter is attached to a bracket with a hose clamp. You will need a special release tool to get the lines off. https://www.2carpros.com/images/external/ASM8027_1.jpg
Oct 7, 2016 at 9:28 AM
JIS001
  • 3,412 POSTS
You would need to remove the fuel tank to replace fuel pump. As for fuel filter, remove the lock clips. You will need a quick line disconnect. You can buy a set at harbor freight. Adding link
http://www.harborfreight.com/catalogsearch/result?q=fuel+line+disconnect
Good luck.
Oct 7, 2016 at 9:31 AM
JIS001
  • 3,412 POSTS
We were answering at the same time almost, LOL.
Oct 7, 2016 at 9:32 AM
RENEE L
  • 1,260 POSTS
Nice work WRENCHTECH and JIS001.
Oct 8, 2016 at 7:41 AM
BULLITT5123
Thanks guys for this information much appreciated! I will be working on my Stang first thing tomorrow.
Oct 8, 2016 at 12:07 PM
  • 55,588 POSTS
Here is a video and guide that may help as well.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://youtu.be/SOmd3BoE4YU
Please let us know what you find so it will help others.
Best, Ken
Oct 10, 2016 at 3:15 PM
