1995 Hyundai Elantra No Acceleration
HYUNDAI
A_LEIX
1995 Hyundai Elantra 106,000 Miles. The basic problem is it has no acceleration from start. It is a manual and has been to the dealership for a diagnostic check for a possible electrical problem. They said it might be a bad catalytic converter and so we got it checked out at an exhaust shop and they said everything is fine and it might be the belt is timed wrong. The belt does look new and feels tight on there. Would the car be performing this way because the belt was timed wrong when a new belt was put on? Any help would be appreciated.
Aug 27, 2006 at 10:58 AM
MIKEYBDMAN
  • 623 POSTS
[quote:c5d1ebf271="A_Leix"]1995 Hyundai Elantra 106,000 Miles. The basic problem is it has no acceleration from start. It is a manual and has been to the dealership for a diagnostic check for a possible electrical problem. They said it might be a bad catalytic converter and so we got it checked out at an exhaust shop and they said everything is fine and it might be the belt is timed wrong. The belt does look new and feels tight on there. Would the car be performing this way because the belt was timed wrong when a new belt was put on? Any help would be appreciated.[/quote:c5d1ebf271]
Did you just get this car? If the belt was replaced before you bought the car, and the timing was off, I would think it would have never run good since you had it. If it jumped a notch on the belt, I would think it would have been very noticable when it happened.
If you think it may be off, then uncover the belt and check the timing marks.
Aug 27, 2006 at 11:03 AM
Suggested Repair
If timing is suspected, uncover the timing belt and verify the timing marks. A belt timed wrong at installation or one that jumped a tooth can cause poor acceleration, though a sudden jump would usually be noticeable when it happened.
Conversation Summary
A 1995 Hyundai Elantra with 106,000 miles has no acceleration from a start. A dealer suspected an electrical issue or a bad catalytic converter, but an exhaust shop found the exhaust fine and suggested the timing belt may be timed wrong. The belt looks new and feels tight. The expert asked whether the problem existed since the belt was replaced and recommended uncovering the belt to check the timing marks.
