1994 Hyundai Pony Melting Vacuum Hose
HYUNDAI
ORDEROFSION
Hi there. I've got a '94 hyundai pony 1.3(?) chintz thats done 64000m. There is what i think is a vacuum diaphram that is connected to the inlet manifold by a 1-2 inch length of rubber pipe and has two small diameter pipes that dissapear somewhere around the carb. The problem is that the main hose keeps melting and bursting , new ones burst in about 2 mins and a new diaphram unit makes no difference . The problem seems to be alot of quite high pressure and very hot air blowing from the inlet manifold into the diaphram and yet it does not look like it is supposed to be anywhere near anything hot. I would appreciate any help or advice with this . Thanks.
Mar 15, 2006 at 8:32 PM
PEPPERMRJ
  • 1,158 POSTS
The only thing I can think of is it is the EGR valve. This valve reduces pollution by letting the engine suck in exhaust fumes. This process lowers combustion chamber temperature thereby reducing emissions. Sounds like the valve needs to be replaced.
Good luck and let us know. :)
Mar 17, 2006 at 12:50 PM
Suggested Repair
Replace the EGR valve. The expert identified the vacuum diaphragm as the EGR valve and recommended replacing it.
Conversation Summary
The owner of a 1994 Hyundai Pony 1.3 described a vacuum diaphragm connected to the inlet manifold by a short rubber hose, with two small pipes near the carburetor. The main hose repeatedly melts and bursts within minutes, even when new, and a replacement diaphragm did not help. Hot, high-pressure air appears to blow from the inlet manifold into the diaphragm. The expert believes the part is the EGR valve and recommends replacing it.
