2001 Hyundai Santa Fe Loses Power Uphill
2001 HYUNDAI
SCOVILPB
My 2001 hyundai santa fe losses power going up hill. It tends to shift up and rev but doent seem to get the power up. I know nothing about cars but I suspect transmission problems what could be my problem
Mar 8, 2006 at 6:23 AM
PEPPERMRJ
  • 1,158 POSTS
Check the AT fluid. A low level, clogged filter, or worn clutches should be suspect.
Good luck and let us know. :)
Mar 10, 2006 at 11:35 AM
Suggested Repair
Check the automatic transmission fluid. Low fluid, a clogged filter, or worn clutches are the likely causes to investigate.
Conversation Summary
The owner of a 2001 Hyundai Santa Fe reports loss of power going uphill, with the transmission shifting up and revving without delivering power, and suspects a transmission problem. The expert advises checking the automatic transmission fluid and suspects a low level, a clogged filter, or worn clutches.
