2003 Hyundai Sonata Rear Spark Plugs
HYUNDAI
RAHERST
I have 2003 sonata v-6;
I can get to the front three pugs with no problem. but the back three seem to be underneath the intake. Is there an easy way to change out these three plugs? As it is they simply cannot be reached.
Thanks
Sep 24, 2007 at 2:21 PM
  • 31,937 POSTS
Hi there,
There is no easy way to get to these plugs, but the up side is that they should be iridium plugs and don't need to be replaced untill 100,000 KM's so if yours is under that distance you may not have to change them. The front plugs are often conventional spark plugs as they are easy to reach.
Mark (mhpautos)
Sep 24, 2007 at 7:07 PM
RAHERST
should I just change out the front ones, and wait to change out the back? I have 90,000 miles on it. Would this make an improvement in the performance?
thanks again
Sep 25, 2007 at 6:19 AM
  • 31,937 POSTS
Hi there,
At 90,000 Mls they should be changed, also replace the fuel & air filter while your at it. As for getting into the rear plugs, make plenty of notes and drawings as to where all the bits go, it's not as bad as it looks, lake your time and you should have no problems.
Mark (mhpautos)
Sep 25, 2007 at 10:16 AM
Suggested Repair
At 90,000 miles, replace all spark plugs, including the rear plugs under the intake, and also replace the fuel and air filters. There is no easy shortcut: note and diagram part locations, take your time, and reassemble carefully.
Conversation Summary
The owner of a 2003 Hyundai Sonata V6 can reach the front three spark plugs but not the rear three beneath the intake. The expert said the rear plugs are typically longer-lasting iridium plugs, but at 90,000 miles all plugs should be changed along with the fuel and air filters. Rear-plug access requires careful disassembly with notes and drawings.
