2000 Hyundai Elantra Power Loss
HYUNDAI
EM
2000 Hyundai Elantra Stanard Shift, 134000KM
Since I got the car in 2000, the car will be driving along fine at high speeds and then feel like all the sudden the power is gone, and then instantly it starts up again - it doesn't acutally stall and the engine light never comes on but it feels like the car kind of misses a beat or something. I had the car into the dealer two days ago and took the mechanic on a long drive to see if he could get the car to do it - (it is happening with more frequency lately) The mechanic was kind of stumped - but said he would try to adjust the throttle on it. The next day, I drove a few errands and noticed the car was bucking and losing power even at low speeds - and now it kind of felt like it was going to stall too - engine light came on - took it back to dealer and they said it is a sensor - could it have anything to do with the fact that the throttle was adjusted??? If it is a sensor - how long to put a new one in? I suddenly don't trust my dealer so much but can't find a site that tells me how long the repair should take so that I have some sort of idea...
Sep 3, 2006 at 7:51 AM
BRUCE HUNT
  • 3,754 POSTS
Nice story but I can't help with out the code that is showing. I would say the adjustment of the throttle was not where to start. You are stating that if I held the throttle constant at say 3000 rpm it would run fine but falter once in awhile. That could be a electrical sensor failing yes. ie cam or crankshaft sensor or it could be a fuel delivery problem such as a filter. The code is imperative.
Nov 3, 2006 at 12:44 AM
Suggested Repair
Do not start by adjusting the throttle. Retrieve the diagnostic trouble code, then check for a failing camshaft or crankshaft position sensor or a fuel delivery problem such as a restricted fuel filter.
Conversation Summary
A 2000 Hyundai Elantra briefly loses power at speed without stalling or a warning light. After a dealer adjusted the throttle, it began bucking at low speed and the engine light came on; the dealer blamed a sensor. The expert said the throttle adjustment was the wrong first step and that the stored code is needed. Possible causes include a failing cam or crankshaft sensor or a fuel delivery issue such as a clogged filter.
