1998 Hyundai Elantra Timing Belt
Suggested Repair
The crank pulley bolt uses right-hand threads and is often easiest to remove with an impact wrench. Because this is an interference engine and the camshafts are not turning, have the cylinder head inspected for valve damage and plan on a new head gasket if the head is removed. Follow a repair manual for the timing belt job.
Conversation Summary
The owner of a 1998 Hyundai Elantra 1.8L with a slipped or broken timing belt asked whether the harmonic balancer bolt is right- or left-hand thread and whether the valves might be undamaged. The engine turns over, but the camshafts do not turn. The expert said the bolt is right-hand thread, an impact wrench is often the best removal method, and head damage is likely on this interference engine, so the head should be inspected.
