timing belt broke need to know what position cam and crank pulleys need to be in also cannot find a mark on crank pulley, thanks
2003 Hyundai Accent Timing Belt Marks
The cam shaft has a hole and at the 12 O'clock position it will line up with a notch on the backing plate, the crank shaft has a timing notch at about the 1 O"Clock position. check the bearings on the idler and the tensioner pulley, and do a comp test after as these engines can do valve damage with a broken belt.
Mark (mhpautos)
Suggested Repair
Set the camshaft hole at the 12 o'clock position so it lines up with the notch on the backing plate, and align the crankshaft timing notch near the 1 o'clock position. Inspect the idler and tensioner pulley bearings, then perform a compression test because a broken timing belt can cause valve damage on this engine.
Conversation Summary
The owner of a 2003 Hyundai Accent 1.6L automatic with 112,000 miles has a broken timing belt and needs the correct cam and crank pulley positions, noting no visible crank pulley mark. The expert says the camshaft hole aligns with a backing-plate notch at 12 o'clock and the crankshaft timing notch is near 1 o'clock. They also advise checking the idler and tensioner pulley bearings and doing a compression test because these engines can suffer valve damage.
