1995 Hyundai Accent Blower Motor Quit
DINOMETIV
Hi i have a 95 hyundai accent and the blower would only work on high last night and then finally it quit altogether.First,i would like to know where to access it (under hood or dash) and if possible,how to test it.thank you,dinometiv
Feb 16, 2006 at 4:19 AM
PEPPERMRJ
  • 1,158 POSTS
The blower motor is located a the right side of the dash at the passengers footwell. Remove the electrical connection, the cooling tube, and the three retaining bolts for removal.
Connect either a test light or voltmeter to the connector to see if power is present.
Good luck and let us know.
Feb 16, 2006 at 7:34 AM
DINOMETIV
Thank you for the info..i checked around while waiting for a response and you were right on the money.I was going to wait till tommorrow because of a bad storm but i sucked it up and found it.Thanks for the info.Will definitely visit the site more often.
Feb 16, 2006 at 11:33 AM
Suggested Repair
The blower motor is on the right side of the dash at the passenger footwell. Disconnect the electrical connector and cooling tube, then remove the three retaining bolts. Check the connector for power with a test light or voltmeter.
Conversation Summary
The owner of a 1995 Hyundai Accent reported the blower worked only on high, then stopped completely, and asked where to access it and how to test it. An expert said the motor is at the passenger footwell on the right side of the dash and explained removal of the connector, cooling tube, and three bolts, plus checking the connector for power. The owner later confirmed the location was correct.
