Hyundai Alternator Belt Screaming
HYUNDAI
MASSJULIE
alternator belt and ac belt are screaming most of the time, especially the alternator belt, which I have replaced 3 times in 2 years. Chunks of rubber are missing from the alternator belt now and rubber is shredding in that area. I am going to have to replace the belt again...but how do I correct this problem or where do we look first?
Jul 24, 2007 at 10:25 AM
CLY
  • 308 POSTS
I would suggest making sure that all the pullies spin freely and that the belt is not contacting anything. Also make sure that the groves were the belt rides are clean of any chunks of rubber and dibris. You may want to take some fine sand-paper and just scuff up all the pullys a bit aswell.....
Cly
Jul 24, 2007 at 10:46 AM
Suggested Repair
Check that all pulleys spin freely and that the belt is not rubbing anything. Clean rubber chunks and debris from the belt grooves, and lightly scuff the pulleys with fine sandpaper.
Conversation Summary
The owner of a Hyundai reports that the alternator and AC belts scream, especially the alternator belt, which has been replaced three times in two years and is now missing chunks of rubber and shredding. The expert recommends checking that all pulleys spin freely, confirming the belt is not contacting anything, cleaning debris from the grooves, and lightly scuffing the pulleys.
