Hyundai Radiator Drain Plug Location
HYUNDAI
APOXTLE
hello, i have a 2003 accent and am going to flush the radiator. can anyone tell me where on the radiator the drain plug is located and what type of plug it is?, any help would be apperciated. thanks a lot.
Aug 19, 2007 at 9:49 AM
LOTT58
location of radiator plug on 2005 elantra
Feb 9, 2012 at 8:35 AM
  • 75,988 POSTS
No information on this-Try this instead of looking for it -disconnect the bottom hose flush it out till its clear and then put in the right type of coolant
Feb 9, 2012 at 10:43 AM
Suggested Repair
If the radiator drain plug cannot be located, disconnect the lower radiator hose, flush the system until the coolant runs clear, and refill with the correct coolant.
Conversation Summary
A 2003 Hyundai Accent owner asked where the radiator drain plug is and what type it is before flushing the radiator. Another user asked about a 2005 Elantra. The expert had no plug location and recommended disconnecting the bottom hose, flushing until clear, and refilling with the correct coolant.
