Rear light and brake lights stay on
  • 109,858 POSTS
Check the brake light switch adjustment. It's on the top of the brake pedal.
Monday, December 31st, 2018 AT 12:04 PM (Merged)
RLM89
  • 1994 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 185,000 MILES
Hi I have a question resolving my car. It has to do with my break lights staying turned on when my car is off. I need to know how fix this problem without myself alwways have to pop the hood and take off my battery wire
thanks alot
MASTERTECHTIM
  • 4,749 POSTS
Replace or adjust the brke light switch. Its located right above the brake pedal and is causing your problem
RLM89
Thanks alot. So far I got the same answer from 3 different mechanics and im sure this is the problem. Thanks again
rob
KINGWADE5
  • 1995 HYUNDAI ELANTRA
  • 4 CYL
  • MANUAL
  • 66,000 MILES
Why do my brake lights stay on even when I am pressing the pedal?
  • 31,937 POSTS
Hi there,
This will normally be a faulty brake light switch which is located at the top of the brake pedal under the dash.
Mark (mhpautos)
If your brake lights are coming On with out stepping on the brake pedal-adjust or replace the brake switch.
2CP-ARCHIVES
  • 4,540 POSTS
  • 1993 HYUNDAI ELANTRA
  • 4 CYL
  • 175,000 MILES
1993 Hyundai Elantra. Just recently I discovered that my brake lights will not turn off. When I lift the brake (from underneath) just a little, the lights will turn off. But, when the brake is left in the normal resting position, the lights stay on. Is it possible that the spring that pulls that the brake up while not in use is worn out and that there is not enough tension to pull it high enough to where the lights won't turn on? If so, do I need to order that part from my dealer?
2CP-ARCHIVES
  • 4,540 POSTS
It sounds as if the brake light switch needs to be adjusted. It is located on the brake pedal leakage up under the dash.
BUBBADAM
Stop Everything! There was recalls on the newer types of of these cars and the problem still exists back then, before replacing the Brake Switch First is to check if your Brake Light Switch Stopper is not missing evidence of Broken rubber or plastic on the drivers floor is a indication. This is a very common problem with these types of cars and I'm not only saying Hyundai but also honda and other models has also same problem.
On the 2004 Hyundai Elantra The stopper is located on the Brake Pedal arm and if its missing the brake light switch will not turn off because the Plunger will go through the hole where the stopper was and not turn the switch off.
A quick fix is double sided tape and a penny but better to fix it properly get a new stopper and replace it than risking your life.
Saturday, August 31st, 2019 AT 5:56 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,259 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Saturday, August 31st, 2019 AT 12:40 PM
SOFTBALL42
  • 4 CYL
  • 60,000 MILES
Brake lights stay on for my 1993 hyndai elantra. I already replaced the switch, could it be the fuse?
Saturday, August 31st, 2019 AT 12:40 PM (Merged)
Check for power before and after the brake switch-got both the brake circuit is open between the switch and the bulb socket
