2000 Hyundai Elantra When the car warms up it turns off.
GABRIELLA37
  • 2000 HYUNDAI ELANTRA
  • 4 CYL
  • 180,000 MILES
Why does the car quit after it has been warmed up?
Saturday, January 16th, 2010 AT 8:50 PM
Could be an ignition or fuel problem-next time it dies out don't wait try to start it immediately if it refuses to start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Saturday, January 16th, 2010 AT 9:32 PM
