2002 Hyundai Elantra A/C Stalls Engine
MTHORNHILL
  • 2002 HYUNDAI ELANTRA
  • 4 CYL
  • MANUAL
  • 103,000 MILES
I just replaced the belt on my A/C Compressor and now the engine stalls when the A/C is on. I though it might have been too tight but when I loosened it, it started to screech and didn't stop the stalling problem. Help please
Wednesday, April 14th, 2010 AT 5:22 PM
OBXAUTOMEDIC
  • 3,711 POSTS
The most likely cause is the A/C Compressor is locked up.
If you have someone that can assist have them start vehicle with a/c off while you are looking at the compressor have them turn the a/c on. Does the Pulley freeze up? If so then your a/c compressor needs to be replaced.
Wednesday, April 14th, 2010 AT 5:36 PM
MTHORNHILL
Pulley spins and A/C runs for a bit
Wednesday, April 14th, 2010 AT 5:42 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Does the Compressor make any noise before it stalls out?
Sounds like the bearings inside the compressor are going. And since the vehicle runs fine when a/c is off the compressor is at fault.
Wednesday, April 14th, 2010 AT 7:33 PM
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
