2001 Hyundai Elantra Car stops running after 20 or 30m
ARMANDOA00
  • 2001 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 121,000 MILES
The car stop running after certain miles. Still on but does not run.I have to turn it off and turn it back on so I can run the car again. It oinly happens when the weather is hot. When its cold it runs good what can it be
Wednesday, August 5th, 2009 AT 6:53 PM
  • 110,053 POSTS
Has the check engine light ever come on? Have you checked fuel pump pressure?
Wednesday, August 5th, 2009 AT 7:11 PM
ARMANDOA00
The engine ligh comes on once a while for 1 day only then turns off. The fuel pressure has not been checked what would the psi be on this model. If I pull over to the side and wait for a minute with the car on, then try to go the car will run about 5 miles an hour very slow.I have to turn it off and then back on to start running normal again for a couple miles.
Thursday, August 6th, 2009 AT 6:12 PM
  • 110,053 POSTS
If the light has been on, there is a trouble code stored in the computer that will help identify the problem. Take the car to a nationally recognized parts store and have them scan it. Most will do it for free. Let me know what you find.
Thursday, August 6th, 2009 AT 8:57 PM
